Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 3 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.5 |
BW @ Acl (MHz) | 1600 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 5100 |
Architecture | Fully Differential ADC Driver, Bipolar |
Vn at flatband (Typ) (nV/rtHz) | 2.2 |
Iq per channel (Typ) (mA) | 37.7 |
Rail-to-rail | No |
Vos (offset voltage @ 25 C) (Max) (mV) | 4 |
Operating temperature range (C) | -40 to 85 |
Output current (Typ) (mA) | 96 |
2nd harmonic (dBc) | 110 |
3rd harmonic (dBc) | 108 |
Frequency of harmonic distortion measurement (MHz) | 10 |
GBW (Typ) (MHz) | 2800 |
Input bias current (Max) (pA) | 15500000 |
Features | Shutdown |
CMRR (Typ) (dB) | 90 |
Rating | Catalog |
- Fully-Differential Architecture
- Centered Input Common-Mode Range
- Minimum Gain of 1 V/V (0 dB)
- Bandwidth: 1600 MHz
- Slew Rate: 5100 V/μs
- 1% Settling Time: 2.9 ns
- HD2: –75 dBc at 70 MHz
- HD3: –86 dBc at 70 MHz
- OIP2: 77 dBm at 70 MHz
- OIP3: 42 dBm at 70 MHz
- Input Voltage Noise: 2.2 nV/√Hz (f > 10 MHz)
- Noise Figure: 19.8 dB
- Output Common-Mode Control
- Power Supply:
- Voltage: 3 V (±1.5 V) to 5 V (±2.5 V)
- Current: 37.7 mA
- Power-Down Capability: 0.65 mA
- APPLICATIONS
- 5-V Data Acquisition Systems, High Linearity ADC Amplifier
- Wireless Communication
- Medical Imaging
- Test and Measurement
All trademarks are the property of their respective owners.
The THS4513 is a wideband, fully-differential op amp designed for 3.3-V to 5-V data acquisition systems. It has very low noise at 2.2 nV/√Hz, and extremely low harmonic distortion of –75 dBc HD2 and –86 dBc HD3 at 70 MHz with 2-VPP output, G = 0 dB, and 200- load. Slew rate is very high at 5100 V/μs and with settling time of 2.9 ns to 1% (2-V step), it is ideal for pulsed applications. It is designed for a minimum gain of 0 dB.
To allow for dc-coupling to analog-to-digital converters (ADCs), its unique output common-mode control circuit maintains the output common-mode voltage within 5-mV offset (typ) from the set voltage, when set within 0.5 V of midsupply, with less than 4-mV differential offset voltage. The common-mode set point is set to midsupply by internal circuitry, which may be overdriven from an external source.
The input and output are optimized for best performance with their common-mode voltages set to midsupply. Along with high performance at low power-supply voltage, this design makes it ideal for extremely high-performance, single-supply 5-V data acquisition systems.
The THS4513 is offered in a quad, leadless QFN-16 package (RGT), and is characterized for operation over the full industrial temperature range from –40°C to +85°C.
