公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
50MHz 至 750MHz 级联放大器
Current consumption (mA) 100
Frequency (Min) (MHz) 50
Frequency (Max) (MHz) 750
Gain (Typ) (dB) 15.5
Impedance match (Ohms) 50
Noise figure (Typ) (dB) 4
Number of channels (#) 1
Operating temperature range (C) -40 to 85
Output enable No
Output IP3 (Typ) (dBm) 36
P1dB (Typ) (dBm) 20.6
Type RF Gain Block
Rating Catalog
Power down current No
  • High Dynamic Range
    • OIP3 = 36 dBm
    • NF < 4.5 dB
  • Single-Supply Voltage
  • High Speed
    • VS = 3 V to 5 V
    • IS = Adjustable
  • Input/Output Impedance
    • 50 Ω
The THS9001 is a medium power, cascadeable, gain block optimized for high IF frequencies. The amplifier incorporates internal impedance matching to 50 Ω, and achieves greater than 15-dB input, and output return loss from 50 MHz to 350 MHz with VS = 5 V, R(BIAS) = 237 Ω, L(COL) = 470 nH. Design requires only 2 dc-blocking capacitors, 1 power-supply bypass capacitor, 1 RF choke, and 1 bias resistor.
