Local sensor accuracy (Max) (+/- C) | 2 |
Type | Local |
Operating temperature range (C) | -40 to 125 |
Supply voltage (Min) (V) | 2.6 |
Interface type | I2C, SMBus |
Supply voltage (Max) (V) | 3.3 |
Supply current (Max) (uA) | 85 |
Temp resolution (Max) (bits) | 12 |
Features | ALERT, One-shot conversion |
Remote channels (#) | 0 |
Addresses | 2 |
Rating | Catalog |
- SUPPORTS 1.8V I2C BUS
- TWO ADDRESSES
- DIGITAL OUTPUT: Two-Wire Serial Interface
- RESOLUTION: 9- to 12-Bits, User-Selectable
- ACCURACY:
- ±2.0°C (max) from –25°C to +85°C
- ±3.0°C (max) from –40°C to +125°C
- LOW QUIESCENT CURRENT:
50μA, 1.5μA Standby - NO POWER-UP SEQUENCE REQUIRED, I2C PULLUPS CAN BE ENABLED PRIOR TO V+
The TMP105 is a two-wire, serial output temperature sensor available in a WCSP package. Requiring no external components, the TMP105 is capable of reading temperatures with a resolution of 0.0625°C.
The TMP105 features a Two-Wire interface that is SMBus-compatible, with the TMP105 allowing up to two devices on one bus. The TMP105 features an SMBus Alert function.
The TMP105 is ideal for extended temperature measurement in a variety of communication, computer, consumer, environmental, industrial, and instrumentation applications.
The TMP105 is specified for operation over a temperature range of –40°C to +125°C.
