公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  198粉丝
--- 产品详情 ---
具有单线 SensorPath 接口的 ± 温度传感器
Local sensor accuracy (Max) (+/- C) 2
Type Local
Operating temperature range (C) -40 to 125
Supply voltage (Min) (V) 2.7
Interface type 1-wire Sensor Path
Supply voltage (Max) (V) 5.5
Supply current (Max) (uA) 120
Temp resolution (Max) (bits) 10
Remote channels (#) 0
Addresses 4
Rating Catalog
  • SensorPath INTERFACE
  • FOUR ADDRESSES
  • RESOLUTION: +0.25°C (10-bit)
  • WIDE TEMPERATURE RANGE: –40°C to +125°C
  • LOW QUIESCENT CURRENT: 110μA (typ)
  • TEMPERATURE ACCURACY: ±2°C (max)
  • EXTENDED SUPPLY RANGE: +2.7V to +5.5V
  • MICRO-SIZE PACKAGES: SOT23-6 or MSOP-8
  • APPLICATIONS
    • MOTHERBOARDS
    • VIDEO CARDS
    • BASE STATIONS
    • ROUTERS
SensorPath is a trademark of National Semiconductor. All other trademarks are the property of their respective owners.
The TMP141 is a digital output temperature sensor that utilizes the single-wire SensorPath interface. The TMP141 is capable of measuring temperatures within 2°C of accuracy over a temperature range of ?25°C to +85°C and 3°C of accuracy over ?40°C to +125°C. Low supply current, and a supply range from 2.7V to 5.5V, make the TMP141 an excellent candidate for a wide range of low-power applications. The TMP141 is available in SOT23-6 and MSOP-8 packages.
