公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有 SensorPath 接口的 ±2°C 温度传感器
Local sensor accuracy (Max) (+/- C) 2
Type Local
Operating temperature range (C) -20 to 125
Supply voltage (Min) (V) 3
Interface type 1-wire Sensor Path
Supply voltage (Max) (V) 3.6
Supply current (Max) (uA) 750
Temp resolution (Max) (bits) 10
Remote channels (#) 0
Addresses 4
Rating Catalog
  • SensorPath Bus
    • 4 Hardware Programmable Addresses
  • Temperature Sensing
    • 0.25 °C Resolution
    • 127.75 °C Maximum Temperature Reading
  • 8-Lead VSSOP Package
Key Specifications
  • Temperature Sensor Accuracy ±2°C (max)
  • Temperature Range ?20 to +125°C
  • Power Supply Voltage +3.0 to +3.6 V
  • Power Supply Current 0.5 mA (typ)
  • Conversion Time 14 to 1456 ms
All trademarks are the property of their respective owners.
The LM95010 is a digital output temperature sensor that has single-wire interface compatible with the SensorPath interface. It uses a ΔVbe analog temperature sensing technique that generates a differential voltage that is proportional to temperature. This voltage is digitized using a Sigma-Delta analog-to-digital converter. The LM95010 is part of a hardware monitor system, comprised of two parts: the PC System Health Controller (Master), such as a Super I/O, and up to seven slaves of which four can be LM95010s. Using SensorPath, the LM95010 will be controlled by the master and report to the master its own die temperature. SensorPath data is pulse width encoded, thereby allowing the LM95010 to be easily connected to many general purpose micro-controllers.
