公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  198粉丝
--- 产品详情 ---
具有 I2C/SMBus 接口的 ±2°C、3.0V 至 5.5V 业界通用温度传感器
Local sensor accuracy (Max) (+/- C) 2
Type Local
Operating temperature range (C) -55 to 125
Supply voltage (Min) (V) 3
Interface type I2C, SMBus
Supply voltage (Max) (V) 5.5
Supply current (Max) (uA) 500
Temp resolution (Max) (bits) 9
Features UL recognized
Remote channels (#) 0
Addresses 8
Rating Catalog
  • No External Components Required
  • Shutdown Mode to Minimize Power Consumption
  • Up to Eight LM75s Can be Connected to a Single Bus
  • Power Up Defaults Permit Stand-alone Operation as Thermostat
  • UL Recognized Component (LM75B and LM75C)
  • Key Specifications:
    • Supply Voltage
      • LM75B, LM75C: 3 V to 5.5 V
    • Supply Current
      • Operating: 280 μA (typical)
      • Shutdown: 4 μA (typical)
    • Temperature Accuracy
      • ?25°C to 100°C: ±2°C (maximum)
      • ?55°C to 125°C: ±3°C (maximum)
All trademarks are the property of their respective owners.
The LM75B and LM75C are industry-standard digital temperature sensors with an integrated Sigma-Delta analog-to-digital converter and I2C interface. The LM75 provides 9-bit digital temperature readings with an accuracy of ±2°C from -25°C to 100°C and ±3°C over –55°C to 125°C.
Communication is accomplished over a 2-wire interface which operates up to 400kHz. The LM75 has three address pins, allowing up to eight LM75 devices to operate on the same 2-wire bus. The LM75 has a dedicated over-temperature output (O.S.) with programmable limit and hystersis. This output has programmable fault tolerance, which allows the user to define the number of consecutive error conditions that must occur before O.S. is activated.
The wide temperature and supply range and I2C interface make the LM75 ideal for a number of applications including base stations, electronic test equipment, office electronics, personal computers, and any other system where thermal management is critical to performance. The LM75B and LM75C are available in an SOIC package or VSSOP package.
