公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  198粉丝
--- 产品详情 ---
具有 SMBus 和 I2C 接口且兼容 ACPI 的三路远程和本地温度传感器
Local sensor accuracy (Max) (+/- C) 3
Type Remote
Operating temperature range (C) -40 to 125
Supply voltage (Min) (V) 3
Interface type I2C, SMBus
Supply voltage (Max) (V) 3.6
Supply current (Max) (uA) 800
Temp resolution (Max) (bits) 8
Features ALERT
Remote channels (#) 3
Addresses 9
Rating Catalog
  • Accurately senses die temperature of 3 remote ICs, or diode junctions
  • On-board local temperature sensing
  • SMBus and I2C compatible interface, supports SMBus 1.1 TIMEOUT
  • Two interrupt outputs: INT# and T_CRIT_A#
  • Register readback capability
  • 7 bit plus sign temperature data format, 1 °C resolution
  • 2 address select pins allow connection of 9 LM83s on a single bus
Key Specifications
[Solid_Square] Supply Voltage 3.0V to 3.6V
[Solid_Square] Supply Current 0.8mA (max)
[Solid_Square] Local Temp Accuracy (includes quantization error)
0°C to +85°C ±3.0°C (max)
[Solid_Square] Remote Diode Temp Accuracy (includes quantization error)
+25°C to +100°C ±3°C (max)
0°C to +125°C ±4°C (max)
The LM83 is a digital temperature sensor with a 2 wire serial interface that senses the voltage and thus the temperature of three remote diodes using a Delta-Sigma analog-to-digital converter with a digital over-temperature detector. The LM83 accurately senses its own temperature as well as the temperature of three external devices, such as Pentium II? Processors or diode connected 2N3904s. The temperature of any ASIC can be detected using the LM83 as long as a dedicated diode (semiconductor junction) is available on the die. Using the SMBus interface a host can access the LM83's registers at any time. Activation of a T_CRIT_A# output occurs when any temperature is greater than a programmable comparator limit, T_CRIT. Activation of an INT# output occurs when any temperature is greater than its corresponding programmable comparator HIGH limit.
The host can program as well as read back the state of the T_CRIT register and the four T_HIGH registers. Three state logic inputs allow two pins (ADD0, ADD1) to select up to 9 SMBus address locations for the LM83. The sensor powers up with default thresholds of 127°C for T_CRIT and all T_HIGHs. The LM83 is pin for pin and register compatible with the LM84 as well as the Maxim MAX1617 and the Analog Devices ADM1021.
