公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  198粉丝
--- 产品详情 ---
具有风扇控制功能的 3°C 双路输出电阻可编程温度开关
SetPoint type Resistor Programmable
SetPoint value (deg C) -40 to 125
Operating temperature range (C) -40 to 125
Accuracy over temp range (Max) (C) 3
Sensor gain (mV/Deg C) 6.2
Output type Open Drain
Supply voltage (Min) (V) 2.7
Supply voltage (Max) (V) 10
Supply current (Typ) (uA) 230
Comparator channels (#) 2
Features Built-in hysteresis, UL recognized
Rating Catalog
Interface type Analog output, Switch
  • Digital Outputs Support TTL Logic Levels
  • Internal Temperature Sensor
  • 2 Internal Comparators with Hysteresis
  • Internal Voltage Reference
  • Available in 8-pin SOIC and VSSOP Packages
The LM56 is a precision low power thermostat. Two stable temperature trip points (VT1 and VT2) are generated by dividing down the LM56 1.250V bandgap voltage reference using 3 external resistors. The LM56 has two digital outputs. OUT1 goes LOW when the temperature exceeds T1 and goes HIGH when the the temperature goes below (T1–THYST). Similarly, OUT2 goes LOW when the temperature exceeds T2 and goes HIGH when the temperature goes below (T2–THYST). THYST is an internally set 5°C typical hysteresis.
The LM56 is available in an 8-lead VSSOP surface mount package and an 8-lead SOIC.
