公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  198粉丝
--- 产品详情 ---
采用气密性 TO 封装、具有 10mV/°C 增益的 ±1.5°C 模拟输出温度传感器
Local sensor accuracy (Max) (+/- C) 3
Operating temperature range (C) -40 to 125
Supply voltage (Min) (V) 5
Supply voltage (Max) (V) 3.01
Supply current (Max) (uA) 400
Interface type Analog output
Sensor gain (mV/Deg C) 10
Rating Catalog
  • Directly Calibrated to the Kelvin Temperature
    Scale
  • 1°C Initial Accuracy Available
  • Operates from 400 μA to 5 mA
  • Less than 1-Ω Dynamic Impedance
  • Easily Calibrated
  • Wide Operating Temperature Range
  • 200°C Overrange
  • Low Cost
The LM135 series are precision, easily-calibrated, integrated circuit temperature sensors. Operating as a 2-terminal zener, the LM135 has a breakdown voltage directly proportional to absolute temperature at 10 mV/°K. With less than 1-Ω dynamic impedance, the device operates over a current range of 400 μA to 5 mA with virtually no change in performance. When calibrated at 25°C, the LM135 has typically less than 1°C error over a 100°C temperature range. Unlike other sensors, the LM135 has a linear output.
Applications for the LM135 include almost any type of temperature sensing over a ?55°C to 150°C temperature range. The low impedance and linear output make interfacing to readout or control circuitry are especially easy.
The LM135 operates over a ?55°C to 150°C temperature range while the LM235 operates over a ?40°C to 125°C temperature range. The LM335 operates from ?40°C to 100°C. The LMx35 devices are available packaged in hermetic TO transistor packages while the LM335 is also available in plastic
