| Protocols | MIPI, CSI, DSI, D-PHY, C-PHY |
| Configuration | 2:1 SPDT |
| Number of channels (#) | 10 |
| Bandwidth (MHz) | 1500 |
| Supply voltage (Max) (V) | 5.5 |
| Supply voltage (Min) (V) | 1.65 |
| Ron (Typ) (Ohms) | 2.45 |
| Input/ouput voltage (Min) (V) | 0 |
| Input/ouput voltage (Max) (V) | 3.6 |
| Supply current (Typ) (uA) | 30 |
| ESD HBM (Typ) (kV) | 2 |
| Operating temperature range (C) | -40 to 85 |
| Crosstalk (dB) | -40 |
| ESD CDM (kV) | 0.25 |
| ICC (Typ) (uA) | 30 |
| Input/output continuous current (Max) (mA) | 35 |
| COFF (Typ) (pF) | 1.5 |
| CON (Typ) (pF) | 1.5 |
| Off isolation (Typ) (dB) | -20 |
| OFF-state leakage current (Max) (μA) | 0.5 |
| Propagation delay (ns) | 0.004 |
| Ron (Max) (Ohms) | 6.5 |
| Ron channel match (Max) (Ohms) | 0.1 |
| RON flatness (Typ) (Ohms) | 0.1 |
| Turn off time (disable) (Max) (ns) | 1000 |
| Turn on time (enable) (Max) (ns) | 300000 |
| VIH (Min) (V) | 1.425 |
| VIL (Max) (V) | 0.5 |
TS5MP645 是一款四数据通道 MIPI 开关。此器件是一款经优化的 10 通道(包含 5 个差动通道)单极双投开关,适用于高速 应用。TS5MP645 可方便地将多个符合 MIPI 标准的器件与单个 CSI/DSI、C-PHY/D-PHY 模块相连接。
此器件具有出色的带宽、几乎不会造成信号恶化的低通道间偏斜以及可补偿布局损失的宽裕量。其低电流消耗可满足低功率 应用供电。
