公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有输入逻辑转换功能的 0.75Ω 导通状态电阻、5V、2:1 (SPDT)、2 通道模拟开关
Configuration 2:1 SPDT
Number of channels (#) 2
Power supply voltage - single (V) 2.5, 3.3, 5
Protocols Analog
Ron (Typ) (Ohms) 0.5
CON (Typ) (pF) 130
ON-state leakage current (Max) (μA) 0.2
Bandwidth (MHz) 43
Operating temperature range (C) -40 to 85
Features 1.8-V compatible control inputs, Break-before-make
Input/output continuous current (Max) (mA) 450
Rating Catalog
Supply current (Typ) (uA) 0.001
  • Specified Break-Before-Make Switching
  • Low ON-State Resistance (0.75 Max)
  • Control Inputs Reference to VIO
  • Low Charge Injection
  • Excellent ON-State Resistance Matching
  • Low Total Harmonic Distortion (THD)
  • 2.25-V to 5.5-V Power Supply (V+)
  • 1.65-V to 1.95-V Logic Supply (VIO)
  • Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
  • ESD Performance Tested Per JESD 22
    • 2000-V Human-Body Model
      (A114-B, Class II)
    • 1000-V Charged-Device Model (C101)
    • 300-V Machine Model (A115-A)
  • COM Inputs
    • 8000-V Human-Body Model
      (A114-B, ClassII)
    • ±15-kV Contact Discharge (IEC 61000-4-2)
  • APPLICATIONS
    • Cell Phones
    • PDAs
    • Portable Instrumentation
NanoFree Is a trademark of Texas Instruments
The TS5A26542 is a dual single-pole double-throw (SPDT) analog switch that is designed to operate from 2.25V to 5.5 V. The device offers a low ON-state resistance with an excellent channel-to-channel ON-state resistance matching, and the break-before-make feature to prevent signal distortion during the transferring of a signal from one path to the another. The device has excellent total harmonic distortion (THD) performance and consumes very low power. These features make this device suitable for portable audio applications.
The TS5A26542 has a separate logic supply pin (VIO) that operates from 1.65 V to 1.95 V. VIO powers the control circuitry, which allows the TS5A26542 to be controlled by 1.8-V signals.
