| Configuration | 2:1 SPDT |
| Number of channels (#) | 1 |
| Power supply voltage - single (V) | 2.5, 3.3, 5 |
| Protocols | Analog |
| Ron (Typ) (Ohms) | 5.3 |
| CON (Typ) (pF) | 8.5 |
| ON-state leakage current (Max) (μA) | 0.003 |
| Bandwidth (MHz) | 100 |
| Operating temperature range (C) | -40 to 85 |
| Features | Break-before-make |
| Input/output continuous current (Max) (mA) | 50 |
| Rating | Catalog |
| Supply current (Typ) (uA) | 0.01 |
- Specified Break-Before-Make Switching
- Low ON-State Resistance (10-Ω Maximum at VCC = 5 V)
- Low Power Consumption
- TTL- and CMOS-Compatible Control Input
- Low Input and Output Capacitance
- Excellent ON-State Resistance Matching
- Low Total Harmonic Distortion
- 2.25-V to 5.5-V Single-Supply Operation
- Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
- ESD Performance Tested Per JESD 22
- 2000-V Human-Body Model (A114-B, Class II)
- 1000-V Charged-Device Model (C101)
- Control Inputs Are 5.5-V Tolerant
The TS5A9411 device is a bidirectional, single-pole double-throw (SPDT) analog switch that is designed to operate from 2.25 V to 5.5 V. The device offers low ON-state resistance, low leakage, and low power with a break-before-make feature. These features make this device suitable for portable and battery-powered applications.
