公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有 1.8V 输入逻辑的 0.9Ω、3.3V、1:1 (SPST)、2 通道模拟开关(2 个高电平有效)
Configuration 1:1 SPST
Number of channels (#) 2
Power supply voltage - single (V) 1.8, 2.5, 3.3
Protocols Analog
Ron (Typ) (Ohms) 0.7
CON (Typ) (pF) 43
ON-state leakage current (Max) (μA) 0.005
Bandwidth (MHz) 125
Operating temperature range (C) -40 to 85
Features 1.8-V compatible control inputs
Input/output continuous current (Max) (mA) 100
Rating Catalog
  • Low ON-State Resistance (Ron)
    • 0.9-Ω Max (3-V Supply)
    • 1.5-Ω Max (1.8-V Supply)
  • 0.4-Ω Max Ron Flatness (3-V Supply)
  • 1.6-V to 3.6-V Single-Supply Operation
  • Available in SOT-23 and VSSOP Packages
  • High Current-Handling Capacity (100 mA
    Continuous)
  • 1.8-V CMOS Logic Compatible (3-V Supply)
  • Fast Switching: tON = 14 ns, tOFF = 9 ns
The TS3A4741 and TS3A4742 are bi-directional, 2-channel single-pole/single-throw (SPST) analog switches with low ON-state resistance (Ron), low-voltage, that operate from a single 1.6-V to 3.6-V supply. These devices have fast switching speeds, handle rail-to-rail analog signals, and consume very low quiescent power.
The digital logic input is 1.8-V CMOS compatible when using a single 3-V supply.
The TS3A4741 has two normally open (NO) switches, and the TS3A4742 has two normally closed (NC) switches.
