| Configuration | 1:1 SPST |
| Number of channels (#) | 1 |
| Power supply voltage - single (V) | 2.5, 3.3, 5 |
| Protocols | Analog |
| Ron (Typ) (Ohms) | 5 |
| CON (Typ) (pF) | 13 |
| ON-state leakage current (Max) (μA) | 0.01 |
| Bandwidth (MHz) | 450 |
| Operating temperature range (C) | -40 to 85 |
| Input/output continuous current (Max) (mA) | 20 |
| Rating | Catalog |
| Supply current (Typ) (uA) | 0.01 |
- Low ON-State Resistance (8
) - ON-State Resistance Flatness (1.5
) - Control Inputs Are 5.5-V Tolerant
- Low Charge Injection (5 pC Max)
- 450-MHz -3-dB Bandwidth at 25°C
- Low Total Harmonic Distortion (THD) (0.04%)
- 2-V to 5.5-V Single-Supply Operation
- -85-dB OFF Isolation at 1 MHz
- Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
- 0.5-nA Max OFF Leakage
- ESD Performance Tested Per JESD 22
- 2000-V Human-Body Model (A114-B, Class II)
- 1000-V Charged-Device Model (C101)
- TTL/CMOS-Logic Compatible
- Applications
- Sample-and-Hold Circuits
- Battery-Powered Equipment
- Audio and Video Signal Routing
- Communication Circuits
The TS5A4596 is a single-pole single-throw (SPST) analog switch that is designed to operate from 2 V to 5 V. This device can handle both digital and analog signals, and signals up to V+ (peak) can be transmitted in either direction.
