| Configuration | 1:1 SPST |
| Number of channels (#) | 1 |
| Power supply voltage - single (V) | 1.8, 2.5, 3.3, 5 |
| Protocols | Analog |
| Ron (Typ) (Ohms) | 7.5 |
| CON (Typ) (pF) | 14 |
| ON-state leakage current (Max) (μA) | 2 |
| Bandwidth (MHz) | 400 |
| Operating temperature range (C) | -40 to 85 |
| Input/output continuous current (Max) (mA) | 50 |
| Rating | Catalog |
| Supply current (Typ) (uA) | 0.05 |
- Low ON-State Resistance (10 Ω)
- Control Inputs Are 5.5-V Tolerant
- Low Charge Injection
- Low Total Harmonic Distortion (THD)
- 1.65-V to 5.5-V Single-Supply Operation
- Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
- ESD Performance Tested Per JESD 22
- 2000-V Human-Body Model
(A114-B, Class II) - 1000-V Charged-Device Model (C101)
The TS5A1066 is a single-pole single-throw (SPST) analog switch that is designed to operate from 1.65 V to 5.5V. This device can handle both digital and analog signals, and signals up to V+ (peak) can be transmitted in either direction.
