公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
2.5V、1:1 (SPST)、2 通道模拟开关
Configuration 1:1 SPST
Number of channels (#) 2
Power supply voltage - single (V) 0.8, 1.2, 1.8, 2.5
Protocols Analog
Ron (Typ) (Ohms) 4
CON (Typ) (pF) 7
ON-state leakage current (Max) (μA) 1
Bandwidth (MHz) 500
Operating temperature range (C) -40 to 85
Input/output continuous current (Max) (mA) 50
Rating Catalog
  • Available in the Texas Instruments NanoFree? Package
  • Operates at 0.8 V to 2.7 V
  • Sub-1-V Operable
  • Max tpd of 0.5 ns at 1.8 V
  • Low Power Consumption, 10 μA at 2.7 V
  • High On-Off Output Voltage Ratio
  • High Degree of Linearity
  • Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
  • ESD Performance Tested Per JESD 22
    • 2000-V Human-Body Model (A114-B, Class II)
    • 200-V Machine Model (A115-A)
    • 1000-V Charged-Device Model (C101)
NanoFree is a trademark of Texas Instruments.
This dual analog switch is operational at 0.8-V to 2.7-V VCC, but is designed specifically for 1.1-V to 2.7-V VCC operation.
The SN74AUC2G66 can handle both analog and digital signals. It permits signals with amplitudes of up to 2.7-V (peak) to be transmitted in either direction.
NanoFree? package technology is a major breakthrough in IC packaging concepts, using the die as the package.
Applications include signal gating, chopping, modulation or demodulation (modem), and signal multiplexing for analog-to-digital and digital-to-analog conversion systems.
