公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
汽车类 5V、4:1、2 通道模拟多路复用器
Configuration 4:1
Number of channels (#) 2
Power supply voltage - single (V) 1.8, 2.5, 3.3, 5
Protocols Analog
Ron (Typ) (Ohms) 100
CON (Typ) (pF) 5.6
ON-state leakage current (Max) (μA) 2
Bandwidth (MHz) 50
Operating temperature range (C) -40 to 105, -40 to 125
Input/output continuous current (Max) (mA) 25
Rating Automotive
  • Qualified for Automotive Applications
  • AEC-Q100 Qualified With the Following Results:
    • Device Temperature Grade 1: –40°C to +125°C
      Ambient Operating Temperature Range
    • Device HBM ESD Classification Level 2
    • Device CDM ESD Classification Level C4B
  • Supports Mixed-Mode Voltage Operation on All Ports
  • Fast Switching
  • High On-Off Output-Voltage Ratio
  • Low Crosstalk Between Switches
  • Extremely Low Input Current
These dual 4-channel CMOS analog multiplexers and demultiplexers are designed for 2-V to 5.5-V VCC operation.
The SN7LV4052A-Q1 devices handle both analog and digital signals. Each channel permits signals with amplitudes up to 5.5 V (peak).
Applications include signal gating, chopping, modulation or demodulation (modem), and signal multiplexing for analog-to-digital and digital-to-analog conversion systems.
