| Configuration | 2:1 SPDT |
| Number of channels (#) | 3 |
| Power supply voltage - single (V) | 1.8, 2.5, 3.3, 5 |
| Protocols | Analog |
| Ron (Typ) (Ohms) | 23 |
| CON (Typ) (pF) | 5.6 |
| ON-state leakage current (Max) (μA) | 2 |
| Bandwidth (MHz) | 50 |
| Operating temperature range (C) | -40 to 105, -40 to 125 |
| Input/output continuous current (Max) (mA) | 25 |
| Rating | Automotive |
- Qualified for Automotive Applications
- ESD Protection Exceeds 2000 V Per MIL-STD-883,
Method 3015; Exceeds 200 V Using Machine Model
(C = 200 pF, R = 0) - 2-V to 5.5-V VCC Operation
- Supports Mixed-Mode Voltage Operation on All Ports
- High On-Off Output-Voltage Ratio
- Low Crosstalk Between Switches
- Individual Switch Controls
- Extremely Low Input Current
This triple 2-channel CMOS analog multiplexer/demultiplexer is designed for 2-V to 5.5-V VCC operation.
The SN74LV4053A handles both analog and digital signals. Each channel permits signals with amplitudes up to 5.5 V (peak) to be transmitted in either direction.
Applications include signal gating, chopping, modulation or demodulation (modem), and signal multiplexing for analog-to-digital and digital-to-analog conversion systems.
