公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
汽车类 5.5V、1:1 (SPST)、单通道模拟开关
Configuration 1:1 SPST
Number of channels (#) 1
Power supply voltage - single (V) 1.8, 2.5, 3.3, 5
Protocols Analog
Ron (Typ) (Ohms) 7.5
CON (Typ) (pF) 13
ON-state leakage current (Max) (μA) 1
Bandwidth (MHz) 300
Operating temperature range (C) -40 to 125
Input/output continuous current (Max) (mA) 50
Rating Automotive
Supply current (Typ) (uA) 1
  • Qualified for Automotive Applications
  • AEC-Q100 Qualified With the Following Results:
    • Device Temperature Grade 1: –40°C to 125°C
      Ambient Operating Temperature Range
    • Device HBM Classification Level H2
    • Device CDM Classification Level C5
    • Device MM Classification Level M3
  • 1.65-V to 5.5-V VCC Operation
  • Inputs Accept Voltages to 5.5 V
  • Max tpd of 0.8 ns at 3.3 V
  • High On-Off Output Voltage Ratio
  • High Degree of Linearity
  • High Speed, Typically 0.5 ns (VCC = 3 V,
    CL = 50 pF)
  • Low ON-State Resistance, Typically ≠5.5 Ω
    (VCC = 4.5 V)
  • Latch-Up Performance Exceeds 100 mA Per
    JESD 78, Class II
This single analog switch is designed for 1.65-V to 5.5-V VCC operation.
The SN74LVC1G66-Q1 device supports analog and digital signals. The device permits bidirectional transmission of signals with amplitudes of up to 5.5 V (peak).
