| Configuration | 1:1 SPST |
| Number of channels (#) | 4 |
| Power supply voltage - single (V) | 2.5, 3.3, 5 |
| Protocols | Analog |
| Ron (Typ) (Ohms) | 21 |
| CON (Typ) (pF) | 5.5 |
| ON-state leakage current (Max) (μA) | 1 |
| Bandwidth (MHz) | 50 |
| Operating temperature range (C) | -40 to 85 |
| Input/output continuous current (Max) (mA) | 25 |
| Rating | Catalog |
- 2-V to 5.5-V VCC Operation
- Supports Mixed-Mode Voltage Operation on All Ports
- High On-Off Output-Voltage Ratio
- Low Crosstalk Between Switches
- Individual Switch Controls
- Extremely Low Input Current
- ESD Protection Exceeds JESD 22
- 2000-V Human-Body Model (A114-A)
- 200-V Machine Model (A115-A)
- 1000-V Charged-Device Model (C101)
This quadruple silicon-gate CMOS analog switch is designed for 2-V to 5.5-V VCC operation.
This switch is designed to handle both analog and digital signals. Each switch permits signals with amplitudes up to 5.5 V (peak) to be transmitted in either direction.
Each switch section has its own enable-input control (C). A high-level voltage applied to C turns on the associated switch section.
Applications include signal gating, chopping, modulation or demodulation (modem), and signal multiplexing for analog-to-digital and digital-to-analog conversion systems.
