公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有 5V 至 3.3V 电平转换的 5V、1:1 (SPST)、单通道、通用 FET 总线开关
Configuration 1:1 SPST
Number of channels (#) 1
Power supply voltage - single (V) 5
Protocols Analog
Ron (Typ) (Ohms) 5
ON-state leakage current (Max) (μA) 1
Operating temperature range (C) -40 to 85
Input/output continuous current (Max) (mA) 128
Rating Catalog
  • 5- Switch Connection Between Two Ports
  • TTL-Compatible Control Input Levels
  • Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
The SN74CBTD1G384 features a single high-speed line switch. The switch is disabled when the output-enable (OE) input is high. A diode to VCC is integrated on the chip to allow for level shifting from 5-V signals at the device inputs to 3.3-V signals at the device outputs.
