| Configuration | 1:1 SPST |
| Number of channels (#) | 1 |
| Power supply voltage - single (V) | 5 |
| Protocols | Analog |
| Ron (Typ) (Ohms) | 5 |
| ON-state leakage current (Max) (μA) | 1 |
| Operating temperature range (C) | -40 to 85 |
| Input/output continuous current (Max) (mA) | 128 |
| Rating | Catalog |
- 5-
Switch Connection Between Two Ports - TTL-Compatible Control Input Levels
- Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
- ESD Protection Exceeds JESD 22
- 2000-V Human-Body Model (A114-A)
- 200-V Machine Model (A115-A)
The SN74CBTD1G125 features a single high-speed line switch. The switch is disabled when the output-enable (OE) input is high. A diode to VCC is integrated on the chip to allow for level shifting from 5-V signals at the device inputs to 3.3-V signals at the device outputs.
