公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有内部下拉电阻的 3.3V、1:1 (SPST)、10 通道 FET 总线开关
Configuration 1:1 SPST
Number of channels (#) 10
Power supply voltage - single (V) 3.3
Protocols Analog
Ron (Typ) (Ohms) 5
ON-state leakage current (Max) (μA) 1000
Bandwidth (MHz) 200
Operating temperature range (C) -40 to 85
Features Powered-off protection
Input/output continuous current (Max) (mA) 48
Rating Catalog
  • Enable Signal Is SSTL_2 Compatible
  • Flow-Through Architecture Optimizes PCB Layout
  • Designed for Use With 200 Mbit/s Double Data-Rate (DDR) SDRAM Applications
  • Switch On-State Resistance Is Designed to Eliminate Series Resistor to DDR SDRAM
  • Internal 10-k Pulldown Resistors to Ground on B Port
  • Internal 50-k Pullup Resistor on Output-Enable Input
  • Rail-to-Rail Switching on Data I/O Ports
  • Ioff Supports Partial-Power-Down Mode Operation
  • Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
This 10-bit FET bus switch is designed for 3-V to 3.6-V VCC operation and SSTL_2 output-enable (OE\) input levels.
When OE\ is low, the 10-bit bus switch is on, and port A is connected to port B. When OE\ is high, the switch is open, and the high-impedance state exists between the two ports. There are 10-k pulldown resistors to ground on the B port.
The FET switch on-state resistance is designed to replace the series terminating resistor in the SSTL_2 data path.
This device is fully specified for partial-power-down applications using Ioff. The Ioff feature ensures that damaging current will not backflow through the device when it is powered down. The device has isolation during power off.
