| Configuration | 1:1 SPST |
| Number of channels (#) | 10 |
| Power supply voltage - single (V) | 5 |
| Protocols | Analog |
| Ron (Typ) (Ohms) | 5 |
| ON-state leakage current (Max) (μA) | 1 |
| Bandwidth (MHz) | 20 |
| Operating temperature range (C) | -40 to 85 |
| Features | Signal path translation |
| Input/output continuous current (Max) (mA) | 128 |
| Rating | Catalog |
- 5-
Switch Connection Between Two Ports - TTL-Compatible Input Levels
- Designed to Be Used in Level-Shifting Applications
The SN74CBTD3861 provides ten bits of high-speed TTL-compatible bus switching. The low on-state resistance of the switch allows connections to be made with minimal propagation delay. A diode to VCC is integrated on the die to allow for level shifting from 5-V signals at the device inputs to 3.3-V signals at the device outputs.
The device is organized as one 10-bit switch with a single output-enable (OE)\ input. When (OE)\ is low, the switch is on, and port A is connected to port B. When (OE)\ is high, the switch is open, and the high-impedance state exists between the two ports.
