公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有电平转换功能的 5V、1:1 (SPST)、4 通道模拟开关
Configuration 1:1 SPST
Number of channels (#) 4
Power supply voltage - single (V) 1.8, 2.5, 3.3, 5
Protocols Analog
Ron (Typ) (Ohms) 30
CON (Typ) (pF) 5
ON-state leakage current (Max) (μA) 1
Bandwidth (MHz) 200
Operating temperature range (C) -55 to 125
Features Break-before-make
Input/output continuous current (Max) (mA) 25
Rating Catalog
  • Wide Analog-Input-Voltage RangeVCC – VEE...0V to 10V
  • Low "ON" Resistance
    • 45 (Typ)...VCC = 4.5V
    • 35 (Typ)...VCC = 6V
    • 30 (Typ)...VCC – VEE = 9V
  • Fast Switching and Propagation Delay Times
  • Low "OFF" Leakage Current
  • Built-In "Break-Before-Make" Switching
  • Logic-Level Translation to Enable 5V Logic to Accommodate ±5V Analog Signals
  • Wide Operating Temperature Range . . . –55°C to 125°C
  • HC Types
    • 2V to 10V Operation
    • High Noise Immunity: NIL = 30%, NIH = 30% of VCC at VCC = 5V
  • HCT Types
    • Direct LSTTL Input Logic Compatibility, VIL = 0.8V (Max), VIH = 2V (Min)
    • CMOS Input Compatibility, Il 1μA at VOL, VOH
The ?HC4316 and CD74HCT4316 contain four independent digitally controlled analog switches that use silicon-gate CMOS technology to achieve operating speeds similar to LSTTL with the low power consumption of standard CMOS integrated circuits.
In addition these devices contain logic-level translation circuits that provide for analog signal switching of voltages between ±5V via 5V logic. Each switch is turned on by a high-level voltage on its select input (S) when the common Enable (E) is Low. A High E disables all switches. The digital inputs can swing between VCC and GND; the analog inputs/outputs can swing between VCC as a positive limit and VEE as a negative limit. Voltage ranges are shown in Figures 2 and 3.
