公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有标准的 '126 型引脚排列的 5V、1:1 (SPST)、4 通道、通用 FET 总线开关
Configuration 1:1 SPST
Number of channels (#) 4
Power supply voltage - single (V) 5
Protocols Analog, JTAG, UART, I2C, SPI, RGMII, TDM, I2S
Ron (Typ) (Ohms) 5
ON-state leakage current (Max) (μA) 1
Bandwidth (MHz) 200
Operating temperature range (C) -40 to 85
Input/output continuous current (Max) (mA) 128
Rating Catalog
  • Standard ’126-Type Pinout (D, DB, DGV, and PW Packages)
  • 5- Switch Connection Between Two Ports
  • TTL-Compatible Input Levels
  • Latch-Up Performance Exceeds 250 mA Per JESD 17
The SN74CBT3126 quadruple FET bus switch features independent line switches. Each switch is disabled when the associated output-enable (OE) input is low.
To ensure the high-impedance state during power up or power down, OE should be tied to GND through a pullup resistor; the minimum value of the resistor is determined by the current-sourcing capability of the driver.
