公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有 TTL 输入的 5V、16:1、单通道模拟多路复用器
Configuration 16:1
Number of channels (#) 1
Power supply voltage - single (V) 5
Protocols Analog
Ron (Typ) (Ohms) 60
CON (Typ) (pF) 50
ON-state leakage current (Max) (μA) 1
Bandwidth (MHz) 89
Operating temperature range (C) -55 to 125
Features Break-before-make
Input/output continuous current (Max) (mA) 25
Rating Catalog
Supply current (Typ) (uA) 8
  • Wide Analog Input Voltage Range
  • Low "ON" Resistance
    • VCC = 4.5V. . . . . . . . 70(Typ)
    • VCC = 6V . . . . . . . . 60(Typ)
  • Fast Switching and Propagation Speeds
  • "Break-Before-Make" Switching. . . . . 6ns (Typ) at 4.5V
  • Available in Both Narrow and Wide-Body Plastic Packages
  • Fanout (Over Temperature Range)
    • Standard Outputs . . . . . . . . . . . . . . . 10 LSTTL Loads
    • Bus Driver Outputs . . . . . . . . . . . . . 15 LSTTL Loads
  • Wide Operating Temperature Range . . . -55°C to 125°C
  • Balanced Propagation Delay and Transition Times
  • Significant Power Reduction Compared to LSTTL Logic ICs
  • HC Types
    • 2V to 6V Operation
    • High Noise Immunity: NIL = 30%, NIH = 30% of VCC at VCC = 5V
  • HCT Types
    • 4.5V to 5.5V Operation
    • Direct LSTTL Input Logic Compatibility, VIL = 0.8V (Max), VIH = 2V (Min)
    • CMOS Input Compatibility, Il 1μA at VOL, VOH
The CD74HC4067 and CD74HCT4067 devices are digitally controlled analog switches that utilize silicon-gate CMOS technology to achieve operating speeds similar to LSTTL, with the low power consumption of standard CMOS integrated circuits.
These analog multiplexers/demultiplexers control analog voltages that may vary across the voltage supply range. They are bidirectional switches thus allowing any analog input to be used as an output and vice-versa. The switches have low "on" resistance and low "off" leakages. In addition, these devices have an enable control which when high will disable all switches to their "off" state.
