公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
5V、1:1 (SPST)、10 通道通用模拟开关
Configuration 1:1 SPST
Number of channels (#) 10
Power supply voltage - single (V) 5
Protocols Analog
Ron (Typ) (Ohms) 5
ON-state leakage current (Max) (μA) 1
Bandwidth (MHz) 200
Operating temperature range (C) -40 to 85
Input/output continuous current (Max) (mA) 128
Rating Catalog
  • 5- Switch Connection Between Two Ports
  • TTL-Compatible Input Levels
  • Latch-Up Performance Exceeds 250 mA Per JESD 17
The SN74CBT3861 provides ten bits of high-speed TTL-compatible bus switching. The low on-state resistance of the switch allows connections to be made with minimal propagation delay.
The device is organized as one 10-bit switch with a single output-enable (OE\) input. When OE\ is low, the switch is on, and port A is connected to port B. When OE\ is high, the switch is open, and the high-impedance state exists between the two ports.
