公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有内部下拉电阻的 5V、2:1 (SPDT)、12 通道通用 FET 总线开关
Configuration 2:1 SPDT
Number of channels (#) 12
Power supply voltage - single (V) 5
Protocols Analog
Ron (Typ) (Ohms) 3
ON-state leakage current (Max) (μA) 5
Bandwidth (MHz) 200
Operating temperature range (C) -40 to 85
Features Break-before-make
Input/output continuous current (Max) (mA) 128
Rating Catalog
  • Member of Texas Instruments' WidebusTM Family
  • 4- Switch Connection Between Two Ports
  • TTL-Compatible Control Input Levels
  • Make-Before-Break Feature
  • Internal 500- Pulldown Resistors to Ground
  • Latch-Up Performance Exceeds 250 mA Per JESD 17
    Widebus is a trademark of Texas Instruments.
The SN74CBT16292 is a 12-bit 1-of-2 high-speed TTL-compatible FET multiplexer/demultiplexer. The low on-state resistance of the switch allows connections to be made with minimal propagation delay.
When the select (S) input is low, port A is connected to port B1, and RINT is connected to port B2. When S is high, port A is connected to port B2, and RINT is connected to port B1.
