| Configuration | 8:1 |
| Number of channels (#) | 1 |
| Power supply voltage - single (V) | 1.8, 2.5, 3.3, 5 |
| Protocols | Analog |
| Ron (Typ) (Ohms) | 40 |
| CON (Typ) (pF) | 25 |
| ON-state leakage current (Max) (μA) | 4 |
| Bandwidth (MHz) | 180 |
| Operating temperature range (C) | -55 to 125 |
| Features | Break-before-make |
| Input/output continuous current (Max) (mA) | 25 |
| Rating | Catalog |
- Wide Analog Input Voltage Range...±5V (Max)
- Low "On" Resistance
- VCC - VEE = 4.5V...70
(Typ) - VCC - VEE = 9V...40
(Typ)
- Low Crosstalk Between Switches
- Fast Switching and Propagation Speeds
- "Break-Before-Make" Switching
- Wide Operating Temperature Range...–55°C to 125°C
- HC Types
- 2V to 6V Operation, Control; 0V to 10V Switch
- High Noise Immunity: NIL = 30%, NIH = 30% of VCC at VCC = 5V
- HCT Types
- 4.5V to 5.5V Operation, Control; 0V to 10V Switch
- Direct LSTTL Input Logic Compatibility, VIL = 0.8V (Max), VIH = 2V (Min)
- CMOS Input Compatibility, Il
1μA at VOL, VOH
Data sheet acquired from Harris Semiconductor
The ?HC4351, CD74HCT4351, and CD74HC4352 are digitally controlled analog switches which utilize silicon-gate CMOS technology to achieve operating speeds similar to LSTTL with the low power consumption of standard CMOS integrated circuits.
These analog multiplexers/demultiplexers are, in essence, the HC/HCT4015 and HC4052 preceded by address latches that are controlled by an active low Latch Enable input (LE\). Two Enable inputs, one active low (E1\), and the other active high (E2) are provided allowing enabling with either input voltage level.
