公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有逻辑电平转换功能的 CMOS 单路 8 通道模拟多路复用器/多路信号分离器
Configuration 8:1
Number of channels (#) 1
Power supply voltage - single (V) 3.3, 5, 12, 16, 20
Protocols Analog
Ron (Typ) (Ohms) 125
CON (Typ) (pF) 30
ON-state leakage current (Max) (μA) 0.3
Bandwidth (MHz) 20
Operating temperature range (C) -55 to 125
Features Break-before-make
Input/output continuous current (Max) (mA) 10
Rating Military
Supply current (Typ) (uA) 0.04
  • Wide Range of Digital and Analog Signal Levels
    • Digital: 3 V to 20 V
    • Analog: ≤ 20 VP-P
  • Low ON Resistance, 125 ? (Typical) Over 15 VP-P Signal Input Range for VDD – VEE = 18 V
  • High OFF Resistance, Channel Leakage of
    ±100 pA (Typical) at VDD – VEE = 18 V
  • Logic-Level Conversion for Digital Addressing Signals of 3 V to 20 V (VDD – VSS = 3 V to 20 V) to Switch Analog Signals to 20 VP-P (VDD – VEE = 20 V) Matched Switch Characteristics, rON = 5 ? (Typical) for VDD – VEE = 15 V Very Low Quiescent Power Dissipation Under All Digital-Control Input and Supply Conditions, 0.2 μW (Typical) at
    VDD – VSS = VDD – VEE = 10 V
  • Binary Address Decoding on Chip
  • 5 V, 10 V, and 15 V Parametric Ratings
  • 100% Tested for Quiescent Current at 20 V
  • Maximum Input Current of 1 μA at 18 V Over Full Package Temperature Range, 100 nA at 18 V and 25°C
  • Break-Before-Make Switching Eliminates Channel Overlap
The CD405xB analog multiplexers and demultiplexers are digitally-controlled analog switches having low ON impedance and very low OFF leakage current. These multiplexer circuits dissipate extremely low quiescent power over the full VDD – VSS and VDD – VEE supply-voltage ranges, independent of the logic state of the control signals.
