公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有地址锁存器的 3 线至 8 线解码器/多路解复用器
Technology Family LS
Number of channels (#) 1
Operating temperature range (C) -55 to 125
Rating Military
ICC (Max) (uA) 18000
  • Combines Decoder and 3-Bit Address Latch
  • Incorporates 2 Enable Inputs to Simplify Cascading
  • Low Power Dissipation … 65 mW Typ
The 'LS137 is a three-line to eight-line decoder/demultiplexer with latches on the three address inputs. When the latch-enable input (GL\) is low, the 'LS137 acts as a decoder/demultiplexer. When GL\ goes from low to high, the address present at the select inputs (A, B, and C) is stored in the latches. Further address changes are ignored as long as GL\ remains high. The output enable controls, G1 and G\2, control the state of the outputs independently of the select or latch-enable inputs. All of the outputs are high unless G1 is high and G\2 is low. The 'LS137 is ideally suited for implementing glitch-free decoders in strobed (stored-address) applications in bus-oriented systems.
