公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有三态输出的六路 2 至 1 通用多路复用器
Technology Family ALS
Function Digital Multiplexer
Configuration 2:1
Number of channels (#) 6
Operating temperature range (C) -55 to 125
Rating Military
  • Select True or Complementary Data
  • Perform AND/NAND (Masking) of A or B Operand
  • Cascadable to Expand Number of Operands
  • Detect Zeros on A or B Operands
  • 3-State Outputs Interface Directly With System Bus
  • Package Options Include Plastic Small-Outline (DW) Packages, Ceramic Chip Carriers (FK), and Standard Plastic (NT) and Ceramic (JT) 300-mil DIPs
The ′ALS857 are hextuple 2-line to 1-line multiplexers with 3-state outputs. The devices can provide either true (COMP low) or inverted (COMP high) data at the Y outputs. In addition, the ′ALS857 perform the logical AND function (A \x95 B) and the clear function as well. The four modes of operation are:
  • Select A-data inputs
  • Select B-data inputs
  • AND A inputs with B inputs
  • Clear
In either of the first two modes, OPER = 0 is high if all the selected A or B inputs are low. The six Y outputs and the OPER = 0 output are all 3-state and rated at 12-mA and 24-mA IOL for the SN54ALS857 and SN74ALS857, respectively. All outputs can be placed in the high-impedance state by applying a high level to the COMP, S0, and S1 inputs simultaneously.
The SN54ALS857 is characterized for operation over the full military temperature range of -55°C to 125°C. The SN74ALS857 is characterized for operation from 0°C to 70°C.
