公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有三态输出的四路 2 线路到 1 线路数据选择器/多路复用器
Technology Family AC
Function Encoder, Multiplexer
Configuration 2:1
Number of channels (#) 4
Operating temperature range (C) -40 to 85
Rating Catalog
  • 3-State Outputs Interface Directly With System Bus
  • Flow-Through Architecture Optimizes PCB Layout
  • Center-Pin VCC and GND Configurations Minimize High-Speed Switching Noise
  • 500-mA Typical Latch-Up Immunity at 125°C
  • Provides Bus Interface From Multiple Sources in High-Performance Systems
This device is designed to multiplex signals from 4-bit data sources to four output data lines in bus-organized systems. The 3-state outputs do not load the data lines when the output-enable (OE\) input is at a high logic level.
To ensure the high-impedance state during power up or power down, OE\ should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
