公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有三态输出的 8 选 1 数据选择器/多路复用器
Technology Family F
Function Digital Multiplexer
Configuration 8:1
Number of channels (#) 1
Operating temperature range (C) 0 to 70
Rating Catalog
  • 3-State Versions of SN54F151B and SN74F151B
  • 3-State Outputs Interface Directly With System Bus
  • Performs Parallel-to-Serial Conversion
  • Complementary Outputs Provide True and Inverted Data
  • Package Options Include Plastic Small-Outline Packages, Ceramic Chip Carriers, and Standard Plastic and Ceramic 300-mil DIPs
These data selectors/multiplexers contain full binary decoding to select one of eight data sources and feature strobe-controlled complementary outputs. The 3-state outputs can interface with and drive data lines of bus-organized systems. When the strobe (G\) input is high, both outputs are in a high-impedance state in which both the upper and lower transistors of each totem-pole output are off, and the output neither drives nor loads the bus significantly.
The SN54F251B is characterized for operation over the full military temperature range of -55°C to 125°C. The SN74F251B is characterized for operation from 0°C to 70°C.
D0, D1,...D7 = the level of the respective D input.
