公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有三态输出的双路 4 线路至 1 线路数据选择器/多路复用器
Technology Family LS
Function Digital Multiplexer
Configuration 4:1
Number of channels (#) 2
Operating temperature range (C) 0 to 70
Rating Catalog
  • Three-State Version of SN54/74LS153, SN54/74S153
  • Schottky-Diode-Clamped Transistors
  • Permits Multiplexing from N Lines to 1 Line
  • Performs Parallel-to Serial Conversion
  • Fully Compatible with Most TTL Circuits
  • Low Power Dissipation
    • 'LS253 … 35 mW Typical
    • 'S253 … 225 mW Typical
Each of these Schottky-clamped data selectors/multiplexers contains inverters and drivers to supply fully complementary, on-chip, binary decoding data selection to the AND-OR gates. Separate output control inputs are provided for each of the two four-line sections.
The three-state outputs can interface with and drive data lines of bus-organized systems. With all but one of the common outputs disabled (at a high-impedance state) the low-impedance of the single enabled output will drive the bus line to a high or low logic level.
