公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
具有三态输出的高速 CMOS 逻辑 8 输入多路复用器/寄存器
Technology Family HCT
Function Digital Multiplexer
Configuration 8:1
Number of channels (#) 1
Operating temperature range (C) -55 to 125
Rating Catalog
  • Edge-Triggered Data Flip-Flops
    • Transparent Select Latches
  • Buffered Inputs
  • 3-State Complementary Outputs
  • Bus Line Driving Capability
  • Typical Propagation Delay: VCC= 5V, CL = 15pF, TA = 25°C
    • Clock to Output = 22ns
  • Fanout (Over Temperature Range)
    • Standard Outputs. . . . . . . . . . . . . . . 10 LSTTL Loads
    • Bus Driver Outputs . . . . . . . . . . . . . 15 LSTTL Loads
  • Wide Operating Temperature Range . . . -55°C to 125°C
  • Balanced Propagation Delay and Transition Times
  • Significant Power Reduction Compared to LSTTL Logic ICs
  • 4.5V to 5.5V Operation
  • Direct LSTTL Input Logic Compatibility, VIL = 0.8V (Max), VIH = 2V (Min)
  • CMOS Input Compatibility, Il 1μA at VOL, VOH
The CD74HCT356 consists of data selectors/multiplexers that select one of eight sources. The data select bits (S0, S1, and S2) are stored in transparent latches that are enabled by a low latch enable input (LE\).
The data is stored in edge-triggered flip-flops that are triggered by a low-to-high clock transition.
In both types the 3-state outputs are controlled by three output-enable inputs (OE1\, OE2\, and OE3).
