公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有存储器的四路 2 输入多路复用器
Technology Family AS
Function Digital Multiplexer
Configuration 2:1
Number of channels (#) 4
Operating temperature range (C) 0 to 70
Rating Catalog
  • Selects One of Two 4-Bit Data Sources and Synchronously Stores Data With System Clock
  • Applications:
    • Dual Source for Operands and Constants in Arithmetic Processor; Can Release Processor Register Files for Acquiring New Data
    • Implements Separate Registers Capable of Parallel Exchange of Contents, Yet Retains External Load Capability
    • Has Universal-Type Register for Implementing Various Shift Patterns, Including Compound Left-Right Capability
  • Package Options Include Plastic Small-Outline (D) Packages and Standard Plastic (N) 300-mil DIPs
The SN74AS298A is a quadruple 2-input multiplexer with storage that provides essentially the equivalent functional capabilities of two separate MSI functions (SN74AS157 and ′AS175A) in a 16-pin package.
When the word-select (WS) input is low, word 1 (A1, B1, C1, D1) is applied to the flip-flops. A high input to WS causes the selection of word 2 (A2, B2, C2, D2). The selected word is clocked to the output terminals on the negative-going edge of the clock pulse.
The SN74AS298A is characterized for operation from 0°C to 70°C.
a1, a2, etc. = the level of steady-state input at A1, A2, etc.
QA0, QB0, etc. = the level of QA, QB, etc. entered on the most recent transition of CLK
