公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
四路 2 线路至 1 线路数据选择器/多路复用器
Technology Family HCT
Function Digital Multiplexer
Configuration 2:1
Number of channels (#) 4
Operating temperature range (C) -40 to 85
Rating Catalog
  • Operating Voltage Range of 4.5 V to 5.5 V
  • High-Current Outputs Drive Up To 15 LSTTL Loads
  • Typical tpd = 15 ns
  • Low Power Consumption, 80-μA Max ICC
  • ±6-mA Output Drive at 5 V
  • Low Input Current of 1 μA Max
  • Inputs Are TTL-Voltage Compatible
  • Buffered Inputs and Outputs
These data selectors/multiplexers contain inverters and drivers to supply full data selection to the four output gates. A separate strobe (G)\ input is provided. A 4-bit word is selected from one of two sources and is routed to the four outputs.
