--- 产品参数 ---
公司logo
北京北极星能源科技有限公司
178內容 |  5.7w浏览量  |  30粉丝
--- 产品详情 ---
BADENbattery-德国baden蓄电池(中国)有限公司-baden叉车蓄电池组1、叉车蓄电池品牌的选择,国内外品牌比较多,品质不同,价格偏差很大,无论选择进口叉车电池或者国产的,控制质量都是工厂的,如果减少铅的用量,电池组内每个单体电池均衡性差,均衡性不一致导致整组电池寿命迅速下降。
2、选择适合的充电机,充电机过大、过小都会导致叉车蓄电池极板硫化,建议配置具备均衡充电或者带脱硫的充电机。
3、二次放电,长期超过允许额定值放电,或者电流比额定输出值要大,以***车电瓶极板松动、掉粉、或者刺穿。
4、补加蒸馏水,这个是基本常识,很多用户误以为加带酸性的补充液,可以增加电池储能电量,其实这样会导致高酸。整组电池容量不储电。
california-industrial-battery-training-service
5
、电池表面电阻增大,要用干布擦干净,避免表面通电过大,电流流失,导致自放电比正常放电还要多。
BADENbattery-德国baden蓄电池(中国)有限公司-baden叉车蓄电池组牵引型电动叉车蓄电池充电操作步骤:
  美国STANGCO蓄电池-叉车蓄电池总代理步骤一:充电准备
  (1)确保待充电车辆钥匙开关处于关闭状态,即整车不带电。
(2)从充电设备上取下充电枪头(注意:充电枪头上集成有按钮锁扣必须按下才可进行正常拔插操作),检查充电枪及车辆端的铿电池充电插座,确保端口内没有水或外来物,及金属端子没有生锈或者腐蚀造成的破坏或者影响。
(3)充电设备后侧为电源开关,推上电源开关,此时电源指示灯亮,此时由于充电枪未连接到车上,充电设备处于待机或关机状态。
步骤二:完成充电连接Get a Rechargeable Forklift Battery with STANGCO
STANGCO Forklift Battery, Accessories and Forklift Battery Repair
With our on-site services, we have the ability to respond to your facility with battery testers to test the current state of your industrial forklift battery. We can provide you with an assessment of your battery and your forklift battery chargers. Full service available for your forklift battery from battery recycling, battery charger repair and accessories.
Forklift Battery, Charger and Recycling Services:
New BBI Forklift Battery with 5 Year Warranty
Battery Testers
Forklift Battery Installation
Forklift Battery Chargers
Fast Charger
Battery Recycling
Accessories
On-site and In-Shop Forklift Battery Repair
Training and Seminars
STANGCO Forklift Battery Installations and Forklift Battery Chargers Repair
BADENbattery-德国baden蓄电池(中国)有限公司-baden叉车蓄电池组Forklift Battery Recycling
With proper battery recycling, you save the environment and with STANGCO, you save your finances! Lead acid batteries contain hazardous materials that can harm our environment. It is imperative to dispose of them properly. Let STANGCO, make it easy. We will haul away and dispose of your industrial forklift batteries at no additional charge to you!
Need assistance installing or uninstalling a battery? Let our specially trained technicians' help you get it right!
Battery Testers
STANGCO battery testers will analyze the current condition of your forklift batteries to help you save money on unnecessary new battery purchases.
Seminars & Training on Forklift Battery Safety
Let STANGCO teach your employees how to care and water your forklift batteries for optimum performance.
Depending on what you need for your business we offer forklift battery chargers that can keep you operating for extended shifts. Our forklift battery chargers can help you manage and extend the life of the forklift battery by avoid overcharging abuse.
Tailored P.M. Programs - Engineering & Consulting
You need your operation to be up and running, but lack the manpower or expertise to plan and install the battery charging system equipment on your own. STANGCO can help. We can create a personalized PM program to fit your needs that will make running your equipment worry free!
将充电枪插到车体端铿电池充电插座上,充电设备自检并给铿电池通讯,当整个系统无故障时,约15s后,充电设备内部继电器吸合,开始充电,充电指示灯亮,同时仪表上会显示充电电压、充电电流值及充电时间和充电故障等信息。
步骤三:充电结束断电操作
当锂电池充满电后,充电设备会自动停止充电,仪表上输出电压、输出电流均为0。此时按下暂停按钮,之后拔掉充电枪头即可,。若锂电池在尚未充满的情况下需要停止充电,需先按下停止按钮,待充电电流降为0(a)后,方可拔掉充电枪头。
  注意:非紧急情况下,请勿使用急停按钮停止充电。牵引型电动叉车蓄电池更换合力蓄电池:当叉车连续使用了一个工作周期,蓄电池电量完全用完时,应及时用另一组已完全充足电的蓄电池换下原叉车上的蓄电池,并对换下的蓄电池进行充电。
  ▲注意
  ·更换蓄电池时,应确保蓄电池与叉车要匹配。使用与叉车不匹配的蓄电池,会使叉车工作时间缩短或者叉车行驶时会倾翻。
  ·更换蓄电池应在平台上进行。
  按照下列步骤更换蓄电池:
  ▲美国STANGCO蓄电池-叉车蓄电池总代理注意
  ·当用另一台叉车作为更换蓄电池的起吊设备时,应采用适当的吊具(属具)。
  ·吊装蓄电池应由专业人员操作。
  a)拔掉蓄电池插头。
  b)打开蓄电池上盖和侧盖。
  采用气弹簧或其它方式以保证锁住蓄电池上盖,以避免蓄电池上盖下落砸伤人体或车体。
  c)松开蓄电池固定装置。
  d)在将蓄电池吊出叉车时,应小心以免碰坏方向盘或其它叉车部件。
  e)在安放好一组己完全充电的蓄电池之后,固定并将蓄电池插头牢固连接。
  f)盖上蓄电池上盖。
BADENbattery-德国baden蓄电池(中国)有限公司-baden叉车蓄电池组美国STANGCO蓄电池-叉车蓄电池总代理注意在打开和盖上蓄电池上盖时,应小心以免压到手指。在起吊蓄电池时,应小心以免蓄电池箱摆动而碰坏车体。
美国STANGCO蓄电池-叉车蓄电池总代理叉车蓄电池作为叉车、牵引车、搬运车、井下矿用机车等设备的直流动力电源,广泛用于机场、车站、港口、蔬菜和水果市场和工矿企业仓库等场所。叉车电池是指以电池来进行作业的叉车专用的电池。也就是电动叉车的电瓶内装的这种蓄电池。而蓄电池是电池中的一种,它的作用是能把有限的电能储存起来,在合适的地方使用。它的工作原理就是把化学能转化为电能。要注意的是:电池最好不要横放!因为,电池的内部一般是22~28%的稀硫酸。电池正放的时候电解液可以淹没极板并且还剩下一点空间如果把电池横放的话会有一部分电极板暴露在空气中,这对电池的极板非常不利,而且一般的电池的观察孔或者电池的顶部都有排气口与外界相通,所以电池横放电解液很容易流出。
地区产品: 广东叉车蓄电池,新疆叉车蓄电池,山东叉车蓄电池,江苏叉车蓄电池,浙江叉车蓄电池,宁夏叉车蓄电池,北京叉车蓄电池,福建叉车蓄电池,湖南叉车蓄电池,陕西叉车蓄电池。
