Qorvo's RFFM6901 is a single-chip front end module (FEM) for application in the 915MHz ISM Band. The RFFM6901 addresses the need for aggressive size reduction for typical portable equipment RF front end designs and greatly reduces the number of components outside of the core chipset thus minimizing the footprint and assembly cost of the overall solution. The RFFM6901 contains an integrated 1W PA, dual port diversity antenna switch, LNA with bypass mode, and matching components. The RFFM6901 is packaged in a 32-pin, 6.0mm x 6.0mm x 1.2mm over-molded laminate package.
| 功能性 | PA, LNA, Switch with Bypass |
| 频率最小值(MHz) | 868 |
| 频率最大值(MHz) | 928 |
| PA 增益(dB) | 30 |
| Pout(dBm) | 30 |
| LNA 增益(dB) | 17 |
| NF(dB) | 1.5 |
| Vcc(V) | 3 |
| PA Icc(mA) | 450 |
| LNA Icc(mA) | 8 |
| 封装类型 | LGA |
| 封装(mm) | 6.0 x 6.0 x 0.975 |
RFFM6204
RFFM6205
RFFM6404
RFFM6406
RFFM6900
RFFM6901
RFFM6903
RFFM6904
RFFM6906
RFFM6907
RFFM6909
