--- 产品参数 ---
公司logo
深圳市聚成恒信电子科技有限公司
1.2w內容 |  99w+浏览量  |  273粉丝
--- 产品详情 ---
 The QPQ1031Q is a compact, high-performance multiplexer module fabricated using a patented LowDriftTM BAW technology with performance optimized to enable carrier aggregation of LTE bands 1 & 3.
The QPQ1031Q leverages the high-Q properties of the LowDriftTM BAW technology to ensure minimal transmit insertion loss in all bands being multiplexed without loading each other. The QPQ1031Q module has also been designed with high cross-isolation which is critical to ensure good receive performance.
关键性能
  • Qualified to AEC-Q200 Grade 3
  • Industry leading compact form-factor: 2.5mm x 2.0mm
  • Minimizes PA current drain with excellent transmit insertion loss
  • Improved RX sensitivity with low RX IL
  • Single-Ended (SE) Ant, TRx Ports
  • RoHS Compliant, Pb-Free Module Package
类型Infrastructure / Defense
频段1, 3
频率(MHz)B1 TX: 1920 – 1980, B1 RX: 2110 – 2170, B3 TX: 1710 – 1785, B3 RX: 1805 – 1880
带宽(MHz)60
插入损耗(dB)B1 TX: 1.9, B1 RX: 1.7, B3 TX: 2.7, B3 RX: 2.5
封装类型6 pin leadless SMT package
封装(mm)2.5 x 2.0
RFFM6909
QM75041
RFMD2080
RFMD2081
QM22246
QM28005
QM28007
QM28011
QM28012
QM28014
QM28017
QM25032
QM26003
QPQ1031Q
QPQ1035Q
QPQ1214
