产品简介
DIODES 的 SBR30A60CTB 这种超级势垒整流器(SBR®)二极管设计用于满足汽车应用的严格要求。它非常适合用作:
极性保护二极管
再循环二极管
开关二极管
产品规格
品牌 DIODES
型号 SBR30A60CTB
名称 30A超势垒整流器
产地 台湾
封装 SOD123F
产品参数
AEC Qualified Yes
Compliance (Only Automotive supports PPAP) Standard
Configuration Dual
Maximum Average Rectified Current IO (A) 30
Peak Repetitive Reverse Voltage VRRM (V) 60
Peak Forward Surge Current IFSM (A) 180
Forward Voltage Drop VF (V) 0.63
@ IF (A) 30
Maximum Reverse Current IR (μA) 500
@ VR (V) 60
主要特征
专利SBR技术提供卓越的雪崩性能比肖特基二极管更强大的性能,确保更坚固耐用可靠的最终应用。
降低了超低正向电压降(VF);效率更高以及冷却器操作。
减少高温反向泄漏;提高了可靠性防止高温运行中的热失控故障
相关型号
SBR30A100CT
SBR30A100CTB
SBR30A100CTE
SBR30A100CTFP
SBR30A120CT
SBR30A120CTE
SBR30A120CTFP
SBR30A150CT
SBR30A150CTFP
SBR30A40CT
SBR30A40CTFP
SBR30A45CT
SBR30A45CTB
SBR30A45CTFP
SBR30A50CT
SBR30A60CT
SBR30A60CTB
SBR30A60CTFP
SBR30E100CT
SBR30E45CT
SBR30E45CTB
SBR30M100CT
SBR30M100CTFP
SBR30M40CTFP
SBR30U30CT
SBR3150SB
SBR3A40SA
SBR3A40SAF
SBR3M100SAF
SBR3M100SB
SBR3M30P1
SBR3U100LP
SBR3U150LP
SBR3U20SA
SBR3U30P1
SBR3U40P1
SBR3U40S1F
SBR3U40S1FQ
SBR3U60P1
SBR3U60P1Q
SBR3U60P5
SBR3U60SA
SBR3U60SLDQ
SBR40100CT
SBR40100CTFP
SBR40150CT
SBR40150CTFP
SBR4040CT
SBR4040CTFP
SBR4045CT
SBR4045CTFP
SBR4060CT
