--- 产品参数 ---
公司logo
深圳市精博仪器有限公司
1.4k內容 |  26w+浏览量  |  76粉丝
--- 产品详情 ---
主要技术指标
Signal Characteristics
◇ 250 kHz to 3 or 6 GHz (settable down to 100 kHz)
◇ +13 dBm @ 1 GHz output power
◇ ≤ -121 dBc/Hz (typ) phase noise at 1 GHz and 20 kHz offset
◇ ≤1.2 ms switching speed in SCPI mode; ≤900 ?s simultaneous frequency, amplitude, and waveform switching in list mode
Modulation and Sweep
◇ AM, FM, øM, and pulse
◇ Digital step and list sweep with simultaneous switching of frequency, power, and waveform
Baseband Generation and Signal Cr
◇ Internal baseband generator (100 MHz RF BW; up to 125 Msa/s sample rate): arbitrary waveform only
◇ Up to 64 MSa playback memory and 100 MSa storage
◇ Create reference signals: WLAN, WiMAX, W-CDMA, cdma2000, GSM, TD-SCDMA - Signal Studio
◇ W-CDMA dynamic range: ≤-76 dBc for 1-carrier and ≤-70 dBc for 4-carrier
Automation and Communication Inte
◇ 100BaseT LAN, USB 2.0, and GPIB
◇ LXI class-C compliant
◇ SCPI and IVI-COM drivers
◇ Backwards compatible with all ESG, PSG, 8648 signal generators, and other vendors´ signal generators
