ADR380和ADR381分别是2.048 V和2.500 V精密带隙基准电压源,具有高精度、高稳定性、低功耗和小尺寸特性。利用温度漂移曲率校正专利技术,可以使电压随温度变化的非线性度降至低点。宽电源电压范围和低功耗特性,使这些器件非常适合3 V至5 V电池供电应用。 ADR380和ADR381均为微功耗、低压差(LDV)器件,可利用仅比输出电压高出300 mV的电源提供稳定的输出电压。两款器件的额定温度范围为−40°C至+85°C工业温度范围,采用3引脚SOT-23小型封装。
特性
• 初始精度:±5 mV/±6 mV(最大值)
• 初始精度误差:±0.24%/±0.24%
• 低TCVOUT: 25 ppm/°C(最大值)
• 负载调整率:70 ppm/mA
• 电压调整率:25 ppm/V
• 宽工作电压范围
2.4 V至18 V (ADR380)
2.8 V至18 V (ADR381)
• 低功耗:120 µA(最大值)
• 高输出电流:5 mA
• 宽温度范围:−40°C至+85°C
• 3引脚SOT-23小型封装,采用标准引脚排列
相关型号器件:
ADR421ARZ-REEL7
ADR421ARZ
ADR421ARMZ-REEL7
ADR421ARMZ
ADR421
ADR420BRZ
ADR420ARZ
ADR420ARMZ
ADR420
ADR40Z
ADR40M
ADR40L
ADR395BUJZ-REEL7
ADR395BUJZ-R2
ADR395B
ADR395AUJZ-REEL7
ADR395AUJZ-R2
ADR395A
ADR395
ADR392WBUJZ-R7
ADR392BUJZ-REEL7
ADR392BUJZ-R2
ADR392B
ADR392AUJZ-REEL7
ADR392AUJZ-R2
ADR392A
ADR392
ADR391BUJZ-REEL7
ADR391BUJZ-R2
ADR391B
ADR391AUJZ-REEL7
ADR391AUJZ-R2
ADR391A
ADR391
ADR390
ADR381ARTZ-R2
ADR381
ADR380ARTZ-REEL7
ADR380
ADR370
ADR366WAUJZ-REEL7
ADR366BUJZ-REEL7
ADR366BUJZ-R2
ADR366B
ADR366AUJZ-REEL7
ADR366AUJZ-R2
ADR366A
ADR366
ADR365WAUJZ-R7
ADR365BUJZ-R2
