INA105 pdf datasheet (Precisio
消耗积分:0 | 格式:rar | 大小:555 | 2008-10-14
刘满贵
分享资料个
The INA105 is a monolithic Gain = 1 differential
amplifier consisting of a precision op amp and on-chip
metal film resistors. The resistors are laser trimmed
for accurate gain and high common-mode rejection.
Excellent TCR tracking of the resistors maintains
gain accuracy and common-mode rejection over
temperature.
The differential amplifier is the foundation of many
commonly used circuits. The INA105 provides this
precision circuit function without using an expensive
precision resistor network. The INA105 is available in
8-pin plastic DIP, SO-8 surface-mount and TO-99
metal packages.
评论(0)
发评论
下载排行榜
