INA104 pdf datasheet (Very-Hig
消耗积分:0 | 格式:rar | 大小:333 | 2008-12-19
王军
分享资料个
The INA104 is a high accuracy, multistage, integrated-
circuit instrumentation amplifier designed for
signal conditioning requirements where very high performance
is desired.
A multiamplifier, monolithic design, which uses Burr-
Brown’s ultra-low drift, low-noise technology, provides
the highest performance with maximum versatility
at the lowest cost and makes the INA104 ideal for
even high volume applications.
Burr-Brown’s compatible thin-film resistors and lasertrimming
techniques are used for minimizing offset
voltage and temperature drift. This advanced technique
also maximizes common-mode rejection and
gain accuracy.
The INA104 also contains a fourth operational amplifier,
specified separately, which can conveniently be
used for some important applications such as single
capacitor active low-pass filtering, easy output level
shifting, common-mode voltage active guard drive,
and increased gain (x 10,000 and greater).
评论(0)
发评论
下载排行榜
