EVAD592R-PMDZ硬件用户指南
消耗积分:0 | 格式:pdf | 大小:537.48KB | 2021-03-23
分享资料个
This version (21 Nov 2019 17:15) was approved by Robin Getz.
EVAL-AD5592R-PMDZ Overview
EVAL-AD5592R-PMDZ is a minimalist 8-channel, 12-Bit, Configurable ADC/DAC/GPIO with on-chip Reference, SPI interface PMOD module. This boards serve as low-cost alternatives to the full-featured product evaluation boards, with terminal block connections and no extra signal conditioning.
This user guide will focus on the hardware aspect of the EVAL-AD5592R-PMDZ including the connectors, indicators, and different configurations a user would require in order to use the hardware. There are also link to the design files as well as software reference designs that use the hardware with example embedded firmware for a real demo.
Simplified functional block diagram
Connectors and Configuration
The following section reviews all the hardware connectors and how to interface to them. It also reviews configurations options and well as important on board indicators.
Analog/Digital I/O Connector (P2 & P3)
Connector Pin No. Pin Name Pin Description
P3 1 CH3 Channel 3 Input/Output
2 CH2 Channel 2 Input/Output
3 CH1 Channel 1 Input/Output
4 CH0 Channel 0 Input/Output
5 GND Ground
6 VDD Power Supply
P2 1 VREF Voltage Reference
2 GND Ground
3 CH7 Channel 7 Input/Output
4 CH6 Channel 6 Input/Output
5 CH5 Channel 5 Input/Output
6 CH4 Channel 4 Input/Output
SPI PMOD Connector (P1)
Connector Pin No. Pin Name ADuCM3029 Pin Function ADuCM3029 Port No.
SPI_PMOD 1 CS SPI1_CS0/GPIO25 P1_09
2 MOSI SPI1_MOSI/GPIO23 P1_07
3 MISO SPI1_MISO/GPIO24 P1_08
4 SCLK SPI1_SCLK/GPIO22 P1_06
5 DGND DGND
6 3.3V +3.3V
7 IO16 XINT1_WAKE2/GPIO16 P1_00
8 RESET SYS_HWRST_N
9 RDY SPI1_RDY/TMR0_OUT/GPIO14 P0_14
10 IO12 SPT0_AD0/GPIO12 P0_12
11DGND DGND
123.3V +3.3V
Test Points
User can also check the SPI signal quality, supply and reference voltage of the board using test points labeld SS, MOSI, MISO, VLOGIC and VREF
Voltage reference configuration
The default connection of AD5592R Vref pin is shorted at pin 1 of JP1 solder jumper where you can easily configure your voltage reference input at pin 1 of terminal block P2, either from external source or internal 2.5V
LED Indicator
The DS1 is the power green LED indicator of the board.
Schematic, PCB Layout, Bill of Materials
Software
评论(0)
发评论
下载排行榜
