AD9265本地FMC卡/ML605 Xilinx参考设计
消耗积分:0 | 格式:pdf | 大小:54.56KB | 2021-04-26
分享资料个
This version (19 Mar 2018 17:37) was approved by Adrian Costina.The Previously approved version (29 Sep 2017 09:23) is available.Diff
AD9265 Native FMC Card Reference Design
Introduction
The AD9265 is a 16-bit, 125MSPS analog-to-digital converter (ADC) featuring a wide bandwidth differential sample-and-hold analog input amplifier supporting a variety of user-selectable input ranges. This reference design includes a data capture interface and the external DDR-DRAM interface for sample storage. It allows programming the device and monitoring it's internal status registers. The board also provides other options to drive the clock and analog inputs of the ADC.
Supported Devices
  • AD9265-FMC
Supported Carriers
Clock Selection
The board provides three (some modification maybe necessary) possible clock path for clocking the AD9265.
  • External passive clock (default).
  • Optional active clock path using the AD9517.
  • Optional oscillator.
Please make sure you have removed or inserted the corresponding components on the board to select the desired clock path.
Downloads
Help & Support
13 Feb 2015 18:57 · rejeesh kutty
评论(0)
发评论
下载排行榜
