OBS交换结构中FDLs和TWC的研究
消耗积分:0 | 格式:rar | 大小:322 | 2009-02-28
敷衍作笑谈
分享资料个
分析了在光突发交换网络中,光突发分组经过光延迟线组后产生的出端冲突问题,以及由此对突发数据包交换丢失率的影响,提出引入可调波长变换器的解决方案,并通过仿真实验加以验证。
关 键 词 光突发交换; 光延迟线组; 可调波长变换器; 出端冲突
Abstract In the paper, we analyse the problem of fiber delay lines output contention, when the bursts are delayed by fiber delay lines, and the bursts lost rate affected by the problem. The solution by introducing the tunable wavelength converter are presented and simulation results are given.
Key words optical burst switching; fiber delay line; tunable wavelength converter; output contention
评论(0)
发评论
下载排行榜
